Fuel Pump Part #?
My fuel pump is toast. After a little bit of research here it appears that either AC Delco or Delphi are the only ways to go for a replacement. I have been searching online, but there are several similar parts that meet the criteria I define (2000 Blazer LS 4x4 2 door). Does anybody have the AC Delco or Delphi part numbers that I need to find?
I'm not trying to spend $350 on a pump to find out its the wrong one. Thanks in advance.. |
http://www.amazon.com/Delphi-FG0072-...ata/B000CGJZ4E
delphi complete 2 Door; Module Code SGK;2000 LS Model ^^cheapest ive found it for only $247.78 & this item ships for FREE Searching for ac delco right now. il edit in a min. edit : ACDELCO Part # MU1755 $275.79 MODULE,F/TNK F/PMP(SENDER & PUMP) 2 DOOR; w/o ROBUST FUEL SYS SENDER(K53) www.rockauto.com It doesnt say if its for a ls etc...but it should work. i dont think theres a difference. If it was me,id get the delphi. |
Scoreeeeeeeeeee^^^^ get it!
Before you buy check out this ebay item 400255118095 !!!
170.99 plus shipping for a geniune ac /delco pump !! |
Thank you very much, you guys just saved me about $130.
Originally Posted by GLBL WMR
(Post 474005)
Originally Posted by blazer chris
(Post 474091)
I was ready to buy a pump from rockauto.com for $315 plus shipping then i figured i better shop a little and wow i found a pump for my 4 dr blazer for $162 shipped for the same pump!! Thats ridiculous !! Thats more money for the holidays!! Good luck!!!
And it's the current one.. Future readers. If it doesnt have the pigtail included, look close at the pump. There's some NOS pumps floating around that use the OE 2x2 connector. Dont buy those. If you use the existing 2x2 connector there is a very high chance you'll be sorry. Unless you replace the one in the harness, they burn out a lot. |
| All times are GMT -5. The time now is 02:21 AM. |
