fuel pump question
2000 blazer,buying new pump IS delphi and ac delco the same thing??????????thank you
May not be the same. Check the below topic:
https://blazerforum.com/forum/2nd-ge...l-pumps-97674/ AC Delco sounds a safer option. |
Originally Posted by Mike.308
(Post 697426)
https://blazerforum.com/forum/2nd-ge...l-pumps-97674/ AC Delco sounds a safer option. Hey, that thread looks familiar! I'm never getting Delphi again. Ac declo all the way. Three Delphi pumps failed me within a few months. The third one didn't even last 15 miles! |
SO hows the pump?....couldnt figure out the no splice thing,,,maybe that was when OE pumps were still alviable???....this is my second pump job,,,last was a 2000 jimmy...same mess...of coarse soldered the wires
Originally Posted by int3414
(Post 697438)
On my 95 the pump is separate from the sending unit. There is a harness that plugs into the pump, so no soldering or splicing or any thing. |
Originally Posted by cleburne red
(Post 697461)
So far so good, only been about 300 or so miles, though.
Need to find Gray Wire going to fuel Pump 2000 Jimmy 4.3, without dropping tank! Any suggestions out there? Need to check Voltage reading...
Anyone out there that may know the color code on the under hood fuse block for fuel pump "PRIME WIRE"coming off bottom of fuse block? ,,need to locate it..
Thanks.. |
Originally Posted by kess
(Post 701252)
Thanks.. It's easy ony 95, but on your 2000 it's still possible. I don't remember exactly, but. I know I've read on here how to do it Do a search, you'll find your answer. Probably in a thread by captain hook, talking about fuel pressure |
Yes, on the 2000 Jimmy, there is a Prime Terminal on the fuse block UNDER THE HOOD, there beside the fuel pressure relay is a Prime Terminal, which goes directly to the fuel pump, uses battery voltage,,key does not have to be on,,it will run the pump as long as it is connected. I am planning on hot wiring that to a inside cab push button switch to prime pump to 61 lbs or so. Having a problem with starting sometimes,,not quite enough fuel pressure, I think due to low voltage going to fuel pump,,as it has a fairly new fuel pump in it,,not by me, but b4 I bought it 1.5 yrs. ago. I have a fuel pressure gauge hooked up under the hood, to monitor fuel pressure,,I leave it there all the time, cause sometimes I don't get enough fuel pressure to start the Jimmy, and if I go out and raise the hood and push the bleed button on the fuel pressure gauge and take the pressure to 0, then it starts right up, no problem. Strange thing,,when I clear the fuel pressure in the fuel line, it starts,,,it will also start with 56 or higher fuel pressure..Think either have low voltage back at fuel pump or maybe some sort of restriction in fuel line or some other odd situation...Has fairly new fuel filter,,about 1.5 yrs. old also. I don't think it is the fuel pump itself, as I get good pressure if I go directly from the battery voltage to fuel pump using that prime terminal hookup on the fuse block that is beside the fuel pressure relay.
thanks for your reply....Weird Problem.. |
My advice, Kess.
Don't do temporary fixes. Pinpoint the problem. Stacking the temporary fixes (like hard-wiring) on top of problems that You didn't troubleshoot is a bad idea. You'll fall into a rabbit hole eventually. |
:icon_that:
Yep. I can understand temp fixes if you just need to get to work the next day, and will fix it on the weekend, or something. But don't leave it that way.
So, you suspect low voltage at rhw fuel pump harness? Have you checked voltage back there, and compared it to battery voltage? I think I had around 0.5v drop on mine, I checked when I was going though my fits with the fuel pump. Check to make sure you have a good ground, as well |
I am really wondering if whoever changed the fuel pump, if they cleaned the tank any at all,,thinking strainer could be in bad shape,,also probably the fuel lines from tank to filter. I know when the filter was changed about 1.5 years ago, it was pretty darn dirty, probably need to look at it again and change it,,be the easiest thing to do for now.,what puzzles me is the fuel pressure I am getting when turning the key to run, and the differnce it is when I go direct from the prime terminal,,about 5/6 pounds more, is why I am thinking low voltage problem. I did do a current test on the fuel pump.it is within specs as far as I can tell,,runs around 7;24 amps with turning on with key, and about 6.94 when testing from battery direct using prime terminal on fuse block. Higher current means higher resistance, thus could be bad connections back there..I do know that a Advance fuel pump was put in, "Carquest"...
The connection at the fuel pump is used regardless of whether you prime it, or turn the key. If you really do have voltage issues, it's somewhere farther up.
To verify, you need to measure voltage with you priming the system, then, with a helper, measure voltage when the key is turned |
