| jimhens82 |
03-27-2013 07:17 PM |
fuel pump wiring issue 2002 Blazer 4dr
Replaced Pump Two Months Ago .... Truck Ran Fine Until Last Night Truck Started Right Up Went To The Store Then Acted Like It Was Out Of Gas ... So As Usual I Grabbed A Can Put 5 Gallons I No Start Cranks Fine So Today I Checked The Relay Its Fine. Got Under The Truck Disconnected Fuel Pump 4 Pin Connector Both Black Wires Were Off The Charts As Far As Continuity Goes So Im Losing Ground Some Where ...But Im Only Getting 5V At The Pump. Im Thinking The Problem Could Be The Splice That Came With My First Pump A Couple Years Ago, Yes I Should Have Checked It Before Replacing The Pump But The Pump Was Covered BY Warranty N Ran Fine So Im Stumped Until I Trace The Harness Any Help Will Be Greatly Appreciated .... Im Also Going To Add An Addtl Ground To Be Safe Thanks In Advance!!!
