Fuel Tank Connection
I had to pull the fuel tank to replace the fuel pump. However, I failed to see a line at the front of the tank. When I dropped the tanked it hung up on the front line and broke the fitting. Anyone know what this is and can it be replaced. It does not look like it can and looks like the whole tank will have to be replaced. It's a 98 Blazer 4WD
Thnx
Eyeblazin
Thnx
Eyeblazin
RE: Fuel Tank Connection
MOVED TO 2ND GEN TECH
The part is replaceable it unscrews a quarter turn i got mine from o reillys they had to order it took a couple days but u can run without it for a little while just don't fill up the tank cause it will spill out on the ground. I will try to find the part number again
DORMAN (OE SOLUTIONS) - Fuel Tank Vent Valve
Item No: 911-001
$16.99 Each
[/align]
1 Per Vehicle
Limited lifetime warranty (View Details) That is part number from oreillys
POSTS COMBINED. PLEASE USE EDIT FEATURE TO MODIFY A POST RATHER THAN ADD ANOTHER BEFORE SOMEBODY REPLIES.
Item No: 911-001
$16.99 Each
[/align]
1 Per Vehicle
Item No: 911-001
$16.99 Each [/align]
1 Per Vehicle
Item No: 911-001
1 Per Vehicle
Great Thank You!!!!
I researched this part and it does not look exactly like mine, but this is not uncommon. Was your tank metal or plastic? Mine is plastic and 18 gallon. Do you know if this part will still work?
Thnx Again
Eyeblazin
Thnx Again
Eyeblazin
COMBINING THREADS
ORIGINAL: eyeblazin
Anyone know if the vent valve is replaceable or where to get a new valve or tank? Mine has a broken vent valve stem. I have done several searches and cannot find a plastic tank.
I have the plastic gas tank from my 98 Jimmy for sale, in Bloomington, IN. $65, plus shipping(or free pickup).
This board won't let me post a link to my Craigslist ad. If you'd search Indianapolis CL auto parts, and search "Jimmy gas tank", you should find it. Or PM me for a pic.
My tank was plastic and it worked for me
To mrafindley
Was the new valve significantly smaller diameter at the top? The one in the tank looks to be about 2" diameter and the new is only about 1 1/4" diameter. I have yet to get the old out to see the actual hole size. Any special trick in getting it out?
Thnx for your input
Very Helpful
Eyeblazin
Thnx for your input
Very Helpful
Eyeblazin
