Fuel tank removal
Well BB-**** Yes this failure will happen with lots of fuel in the tank!Read all the posts on this site!Its not that bad-just a pita. If you live in the rust belt order up the main strap retainer hardware, as you will most likely have to cut it off! I have seen and heard of folks cutting through the floor,but I can't say as that would be a good idea-however many swear by this method!
By main strap retainer, you mean the piece that is a strap on one end and a bolt on the other? When I did mine I bought a clothesline hook for about $2 to replace it.
In Minnesota, we use salt in the winters to keep ice off the roads. Salt is a natural moisture attractant, any exposed steel will quickly begin to rust. DIRTFT (pronounced dirt foot) or do it right the first time has always been my philosophy.
I was told I need a new fuel tank on my 99 blazer, the lock ring is leaking. I have a plastic tank. I hope to avoid removing the tank to check it, before having a new one here, so I am wondering if the lock ring is part of the tank, or a separate part. Being a plastic tank, are all the parts, seals, lock rings, etc are separate parts. My local parts store has any part in stock, but hope to avoid ordering a tank if I don't need to.
Thanks,
Mike
Thanks,
Mike
The lock ring is available seperate:
Spectra Premium Lock Ring TR19: Find best Fuel Tank Lock Ring at Advance Auto Parts
The O ring is also available seperate at the dealer, or it comes with a new module. If you're changing the lock ring, replace the O ring too. When you remove the old lock ring, the O ring will swell up and it will not seal.
Lastly, one of the fuel line connectors going into the fuel pump looks to have been replaced with sum type of metal retaining clip that is different than the others. I've gotten the stem of the fuel pump that went into it stuck in it. I can probably get it out and re-use it, but does anyone know if autozone or advanced or napa sell the connectors in case I need a new one? Again, links are appreciated.
The steel fitting, (with the broken nipple inside), needs to be replaced. If it is the pressure line, (3/8") the replacement number is Dorman 800-082. If it is the return line, (5/16") the replacement number is Dorman 800-080. These are type of clamps that you need: Autocraft 3/8" Automotive Fuel Injection Hose Clamp (4-Pack) AC52F16V: Get the best Hose Clamp at Advance Auto Parts Do not use the worm gear style of clamp in the image.
The vent fitting should also be replaced, no guarantee if repairing would work.
