G80 Dif Fluid
Hello All,
I have the g80 rear axle in my 96 and I want to replace my dif fluid. What kind should I use? |
From the owner's manual:
Rear Axle (Locking Differential) Axle Lubricant; use only GM Part No. 1052271. Do not add friction modifier. |
Been discussed quite a bit before. Use regular 80w90 GL-5 gear lube. Nothing special required.
| All times are GMT -5. The time now is 06:42 AM. |
