Gas leaking from my vent solenoid aka Vapor Canister Purge Valve
Old Jun 29, 2010 | 11:44 PM
cmaddox421's Avatar
cmaddox421 is on a distinguished road
Default Gas leaking from my vent solenoid aka Vapor Canister Purge Valve
Just wondering if anyone knows of some common causes of gas leaking out of the Vapor Canister Purge Valve only when the vehicle is running and if simply relplacing it is all that is necessary. This is on my 1999 Trailblazer 4.3 V6 4x4. Recently had the fuel pump replace (2-3 months ago).
Thanks for any help!!!
Old Jun 30, 2010 | 06:04 PM
RonJon's Avatar
RonJon is an unknown quantity at this point
Whatever the cause is for gas to come out of the vent solenoid I don't think it's "common". Only suggestion I can think of is replace the charcoal canister. (probably cheaper to get one from a boneyard). That canister has 3 lines: vapors from the tank, air from the vent solenoid, and separated fuel that goes to the purge solenoid on the engine. Whatever is in the canister that separates things and lets them flow to the proper places (check valves I'm thinking) has gone badly wrong I'd say. I'm amazed there's no check engine light and I can't think of any way a fuel pump replacement could cause this issue.
Old Jun 30, 2010 | 06:26 PM
cmaddox421's Avatar
RonJon,
Thanks for taking time to respond to my post. The check engine light has come on, but it kept going off. We just today ran a diagnostic check at AutoZone and it said that the fuel tank pressure sensor is bad. Could this be the cause of the problem?
Old Jun 30, 2010 | 07:09 PM
RonJon's Avatar
The thing I'm trying to figure out is where pressure is coming from to lift fuel to the level of that vent solenoid. Only thing I can figure is when the purge solenoid opens on the motor the liquid fuel in the purge line is siphoning back through the canister. (engine is above that level, rest of the system is below it). Personally I'd say the canister is flawed and the trouble code is due to the EVAP system not working as expected by the Powertrain Control Module. The fuel system is always generating negative pressure at the tank because it's always pumping out more fuel than what returns (while the engine is running). It's possible the pressure sensor has a flaw (or your mechanic didn't plug it in well while replacing the pump) but that wouldn't cause the fuel coming out of the vent solenoid. I still say start with the canister.
Old Jun 30, 2010 | 07:15 PM
surfing007's Avatar
surfing007 is on a distinguished road
How did you notice the leak? I have had this problem also, but have not been able to find the exact location that the gas is leaking from.
Old Jun 30, 2010 | 07:49 PM
cmaddox421's Avatar
Surfing007: Well, I ran into the store and left my wife and kids in the blazer. We kept it running because it was gonna be a quick trip in and she wanted to run the A/C. When I came out, I saw the puddle underneath the rear of the vehicle and it was gas. I could see that it was dripping onto then off of the spare tire, so I took the spare off. I put my finger underneath the vent solenoid, behind the bracket that holds it and could feel it coming out the bottom of the solenoid.
RonJon: Thanks for the info!! It is likely that I will start with a boneyard canister... new is like $150+. Just in case though, is there anything else that might cause the excessive build up of pressure? Are you sure that improper installation of the fuel pump can't be to blame? We've been smelling the gas since the repair. You've been a great help, thank you!
Old Aug 18, 2013 | 12:12 PM
teklife256's Avatar
teklife256 is on a distinguished road
I have a similar issue with fuel leaking from the vent solenoid. Were you able to find a solution? Thanks in advance!
Old Aug 18, 2013 | 12:52 PM
When the fuel pump module is replaced, if the fuel return line and the vapor line are transposed, (tough to do, but it can be done) it will cause what you're describing.
Overfilling the fuel tank can also cause it. At the gas station, when the pump shuts off, the tank is full. Continuing to add fuel will cause raw fuel to enter the canister. If/when that happens, the canister must be replaced, (it is not designed to handle raw fuel).
Old Dec 29, 2013 | 08:33 PM
cody84's Avatar
cody84 is on a distinguished road
I just did this. Replaced fuel pump and mixed up the return and evap lines. Horrible. Still trying to get the evap test to run so that I can pass my ripoff etest.
Tony H
Jan 21, 2011 10:11 AM
Franco
Jan 6, 2011 11:01 AM
Jeff229
17
Nov 11, 2010 01:25 PM
Tony H
Feb 23, 2010 08:09 AM
god_zilla00000
14
Jan 5, 2010 05:26 AM
