Gas Lines HELP!!!!!!!
Long story short. Fuel pump went out and my
"friend" got me a different one. Sadly it is for a 01' malibu. i am getting a new fuel pump for my 97 blazer 2 door but i am having trouble. what size are the fuel lines coming out of the pump? i want to get the nylon quick disconnect lines but they only come in a certain length. i can buy a 10 ft roll of the nylon fuel line but it doesnt come with the quick disconnect ends.... i dont want to rig my lines like i had to do the last time.....this project is stressing me out. can anyone help? any advice? i dont want to buy brake line and bend it.....wha tis the best way tio do this?
Guest
Posts: n/a
Napa 5 16" Quick Disconnect GM Chrysler Nylon Fuel Line Repair Kit 730 4920 | eBay
Dorman Nylon Fuel Line Repair Section 5 16 Inch | eBay
On ebay type in nylon fuel line automotive. All kinds of fuel line repair kits and connections.
If had to guess I would say the size is 3/8
If you deal with a place like Napa they probably have a pump in stock and can actually check it for you
Nylon is a little hard to work with, because most is designed to be stretched over the fitting and then it shrinks back down on the fitting
Without the special tools, connentions can be a bit of a PIA or even impossible
I would prefer to run steel line front to back and use one of the repair ends with a piece of rubber fuel injection hose and fuel injection clamps to connect the pieces
Gary MusicMan
May 2, 2015 01:17 PM
1sttimejimmyowner
Oct 18, 2012 10:59 AM
SnowRemorse
Jan 4, 2008 11:26 AM
