gas tank stuck wont drop down need help?
Old Jan 11, 2010 | 09:07 PM
teryx750's Avatar
teryx750 is on a distinguished road
Default gas tank stuck wont drop down need help?
ive got a 98 chevy blazer 4 door 4x4 with the steel gas tank with a bad fuel pump...i was going to change it but when i went to let the tank down it wouldnt drop down...any ideas to why...i unhooked all the vent lines, filler necks and straps.. please let me know or give me a call and explain 803-517-8861
Old Apr 4, 2010 | 06:22 PM
jmack15's Avatar
jmack15 is on a distinguished road
I have an 2001 and i just dropped the tank. There was one side of the tank towards the rear tire that had a bunch of lines and there was one line by itself on the other end, also im not sure if your heat sheild on the tank might be causing the problem if its bolted to the tank as well as the frame.
Old Apr 5, 2010 | 02:43 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Sounds like your left strap is hung up on one of the lines. There are 3. Pressure, return and vent. If you don't have much fuel in the tank it's light enough for any one of these lines to stop the program.
Old Sep 25, 2021 | 08:14 PM
pimpin's Avatar
pimpin is on a distinguished road
i have the same problem as he has, you take off the two straps and two fill tubes, and the tank still doesnt drop,
it has nothing to do with the wires or hoses, the metal tanks are really stuck in there, i still havent got mine out
MEGearHd
Apr 6, 2019 09:06 PM
ff_malone
Jan 4, 2010 02:26 AM
cnmcconnell
May 17, 2009 05:14 PM
Hey Blue
Feb 7, 2009 08:18 AM
lennyblazer
Jun 19, 2007 06:03 AM
