Getting at fuel pump through cabin?
Has anyone considered locating the location of the pump from the inside? If I could peel back the carpet and cut a small hole in the floor, it might be easier for a one man operation. Thoughts?
Additionally, if someone knows a resource for the type of schematic that would provide me with a roughly 12" diameter access port that is clear of critical components, that would be super. I'd get out the reciprocating saw and give it a try. |
air chisel with cutting bit works better
Guys did this with the late 80's camaros because it is a alot of work to get the tank off they cut a 1/2 -3/4 circle , bent it up Afterwards spot weld it back down |
3 Attachment(s)
Originally Posted by Verwah
(Post 566674)
Additionally, if someone knows a resource for the type of schematic that would provide me with a roughly 12" diameter access port that is clear of critical components, that would be super. I'd get out the reciprocating saw and give it a try. Measure twice, cut once. Also, a jig saw, and hack saw will be your best bet on this one, no sparks at all. and a super clean cut, which will be easiest to seal up. I would not spot weld it, honestly, you can get a better result if you did it the way I told you. Then, down the road when you need to do it again, simple. https://blazerforum.com/forum/attach...ine=1360285940 https://blazerforum.com/forum/attach...ine=1360285940 https://blazerforum.com/forum/attach...ine=1360285940 |
Thanks for the info. I might try this
the access panel, its a beautiful thing. alot of foreign cars actually put panel above the fuel pump. when i do mine i just drill a small hole right about where you kinda guess where one of the corners would be, and just lave the drill bit hanging down through the floor and look under the truck and make sure its in the right place then do the 4 corners like pictures above.
Believe it or not - Buick Park Avenue's have access doors to the fuel pump in the trunk. I dropped the tank to replace the pump and - hey what's that up there... DOH!
I went to a junkyard and cut the cargo area out of a totaled blazer. Took measurements from that and paid for the floor. Picked my carpet up, transfered my measurements to the blazer, and cut it out with an agle grinder with a cut off blade 1 foot by 1 foot. Used the floor from the totaled blazer to make a 16x16 inch patch panel. Cleaned up the burrs, painted cut edges, silicone and screws to attach.
Guys with 4x4 trucks cut access holes in their beds for easier trail fixes. Under the carpet (or vinyl mat) of a blazer nobody ever knows. |
Richphotos, what brand blade did you use when you made the cuts? I'm thinking because of the relative closeness to the fuel lines a short blade would have to be used in this situation.
Also, would you be able to provide us some dimensions for reference? The placement of your hatch looks perfectly placed. |
its 1'x1' as for measurements, from side to side and front to back, I just went between the body and frame outside and measured with a yard stick, and transferred those to the inside, it worked out really well.
Sorry, i dont have the measurements anymore. as for the blade on the jig saw, I used a shorter metal cutting blade, it cut through the sheet metal like butter, there will be a floor support that was a bit tricky to get through, but for that, I just took the blade off of a hack saw, and put on a pair of work gloved and got through that with the hack saw blade. |
Having a 2-door Blazer, I guess I will just drop the tank since its easier than the 4-door. I have been against the odds with the weather latey, and the truck being in my slightly inclined driveway. I am going to be on my back in the cold rain. Thanks for all the info though! Good stuff.
| All times are GMT -5. The time now is 12:03 AM. |
