Got antifreeze in transmission, now stuck in 3rd gear (sometimes)
Calling all 4l60e experts!
So my blazer has been running great (1997 4x4) until one day the trans became stuck in 3rd gear and I noticed transmission fluid was gushing out of my coolant reservoir overflow. I replaced the radiator and flushed the trans about 5 times, and flushed the coolant system several times as well. After doing this the Blazer ran great for about a year. Now its doing it again, and I replace the fluid + filter, and its good for a few days, then its starts doing it again. Sometimes its stuck, but I turn the car off, and then on again, and then it works fine (weird?). Is this a PCM problem, shift solenoids, or do I just need a rebuilt trans? |
Does the check engine light turn on with the bulb check?
Is the check engine light on while driving? If so, what DTC's are in memory? Only one way for trans fluid and coolant to mix... bad radiator. Sticking in 3rd gear could be a stuck solenoid inside the trans. If the solenoid has a problem, it should set a DTC in memory. |
The radiator was replaced about a year ago because of the trans/coolant mixing, I flushed the trans 4-5 times since then with amsoil atf (great stuff), seemed to work great just after flushing/filter change. These are the codes that are currently in memory:
p0740 torque converter clutch circuit open p0753 shift solenoid a electrical p0758 shift solenoid b electrical p0785 shift/timing solenoid malfunction p1860 TCC PWM Solenoid circuit electrical Is this a bad solenoid or what? |
Did you read up on the codes in the Diagnostic Trouble Codes (DTCs) section?
Originally Posted by rriddle3
(Post 554214)
Sounds like you got a bum replacment radiator.
Check all fuses and visually check the connector at the front right corner of the transmission. Large round grey connector, maybe 12 wires or so, might be loose.
Originally Posted by spittybays
(Post 554269)
Ignition switches, so many oddball problems, snap-on should make a kit with interchangeable heads to run diagnostics. Most likely would be too expensive for most mechanics.
looks like this problem is back again. I changed the ignition switch (again) with a brand new unit from ac delco, made no difference. Does anyone know which pins to check for power on the harness (the connector near the trans pan)?
| All times are GMT -5. The time now is 11:03 AM. |
