Grease points?
Hi again....
Does anyone have maintence schedule for the grease points? Where and what you should grease up? I'm not sure that "grease point" is the right name for it? But I'll hope you understand what I mean? /Michael |
RE: Grease points?
uppper and lower ball joints, located right inside each front wheel, it's what they pivot on. VERY IMPORTANT! Pitman arm and tie rod ends. 7 points total on the front end. You may have to feel around and find the grease points. Any place where there is a pivot point you should be able to grease it. If you find a point that does not take grease change the zirk (the thing that a grease gun fitting fits over). Also check U joints.
RE: Grease points?
Schedule, when you change the oil. 3000 miles
RE: Grease points?
Ok thanks alot, now I know I didn't miss any of them.... There are no grease ponits in the back?
Thanks again //Michael |
RE: Grease points?
Hopefully, the Forum posting feature will work for these diagrams of the lube points.:)
[IMG]local://upfiles/4800/90ADB6906DA44D2980C48D8FE18862B3.gif[/IMG] (1) Transmission (2) Rear Axle Differential (3) Transfer Case (4) Clutch Actuator (5) Brake Master Cylinder (6) Engine (7) Front Wheel Bearings (8) Front Axle Differential (9) Oil Filter (10) Front Propeller Shaft (11) Steering Linkage (12) Ball Joints FIGURE Lubrication Fittings (Driver Side)(c) [IMG]local://upfiles/4800/F5BCCBDDA0AD4B44A4E2CF65E412FD69.gif[/IMG] FIGURE Lubrication Fittings (Passenger Side)(c)[IMG]local://upfiles/4800/95DE1824323D47B3BC540D38B0A1D689.gif[/IMG] [IMG]local://upfiles/4800/21E2F5FFE6E245C9BB2E3A9BD9022B9F.gif[/IMG] (1) Ball Joint Lubrication Fittings |
RE: Grease points?
Thanks excellent. Is there anything else you should consider doing wile you are serviceing you veichle.......
Thanks guys....!! //Michael |
| All times are GMT -5. The time now is 06:04 AM. |
