-   -   having problems charging AC 1998 blazer (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/having-problems-charging-ac-1998-blazer-45084/)
blainenbecky 05-29-2010 09:24 AM
I have a 1998 Blazer 4 door 2 wheel drive.
The air does not blow cold, so I tried charging with a can of 134A through a little service port (plastic line) and I jumped the pressure switch to make the compressor run but the gas would not leave the can into the AC system. And the gauge on the applicator was well into the red zone indicating too much pressure. Am I putting the gas in the right inlet by using the service port or is there somewhere else to connect my 134A applicator into?
Thank you for any help you may have on this issue.
1998MSO 05-29-2010 09:34 AM
You should be connecting to the low pressure service port located on the accumulator/receiver (The Silver can near the firewall).
blainenbecky 05-29-2010 11:48 AM
thanks,that got it,
she's nice and cold now,
blainenbecky 07-05-2010 01:31 PM
can any one tell me the spark plug gap for a 1998 balzer with a 4.3 motor.
thanks
84BlazerS10 07-05-2010 02:45 PM
Your best be would be to start a new topic but, if you get ACDelco they should come already gaped.
