Headlight adjuster, where can I find one
My headlight adjusters are stuck and I need to adjust the headlight which are now to high. Don't pass inspection as they are now.
I need the part in the red square. Have searched but can't come up with any source. The picture is from LMC Trucks but his part is not listed. https://cimg9.ibsrv.net/gimg/blazerf...6a5e29d927.png Any advice appreciated Thanks |
I would suggest getting a headlamp assembly from a wrecking yard. Then depending on the quality of the replacement, either swap it in or disassemble it and the original, and swap the mechanism.
New headlamp assemblies can be purchased but I found they don't have quite the same mechanisms like the originals. The adjustments used phillips head screws instead of the Torx. The retainers for the bulbs were not as secure either. So, in order to have the new lenses, I swapped the adjustment mechanisms from the original assemblies to the new ones and then installed the new assemblies. |
You can still buy it from GM or a GM parts reseller.
16524356 |
Originally Posted by LesMyer
(Post 750175)
16524356 |
I wanted these for a 1968 Chevy c10. The plastic clasps and changing screws work great and fit well. Anyway the springs are some unacceptable orinetation for my truck. I would purchase these again as the unit is less expensive here than any of my neighborhood vehicle parts stores.
192.168.100.1 192.168.1.1 |
| All times are GMT -5. The time now is 04:06 AM. |
