headlight bulbs
Can someone please explain to me how to change out the high/low bulbs on my 98' Jimmy. Does the battery and other things need to be removed? or any special tools needed?
any recomendations on a good bulb, possibly a higher wattge? I'd like to get away from the old yellow color, the white and blues ones seem interesting.....silverstars? They also need to be aimed really really bad, and my dad said they use a certain machine/device to do it.....? or can it be done halfassed? thanks for any help |
RE: headlight bulbs
You should see two plastic clips behind the radiator core support for each of the headlights. pull these up to disengage them, then rotate the top of the headlight forward and pull up to disengage the tabs on the bottom of the rear framework. You have to make sure that when you put them back in that these lower tabs fully seat down into the slots they go into or your headlights will be way off. Once you have the housings out, unhook the wiring and replace the bulbs.
Now on bulbs... I have never been a fan of the blue tinted bulbs. But that is primarily because I am a skier (well, was until I blew out my knee) and amber lenses help to highlight the contours of the landscape. Yellow light is actually better to 'see' what's ahead of you. Blue light glares more and gives you the perception that the lights are brighter. When the bulb is clear, you are getting all of the light output from the filament. By placing a colored filter on it, you are effectively limiting the light output to get the desired color. I used Silverstar bulbs in my old intrepid and in the summer time, they were good. I absolutely hated them in the winter because of the glare created by the blue tint. That and I hated the fact that they blew after only 5 months of use. Silverstars are known for their low lifespan. http://i11.photobucket.com/albums/a1...ght_screen.gif
Quad Beam Mod & 9005 Bulb Mod |
RE: headlight bulbs
ok, so i did a little searching, and silverstars are out.......but i still dont know what brand to go with......anyone know the stock bulb wattage? and how many watts is it safe to go with....dont want my headlights melting like that one dude.......or a fire in my steering colume like the intrepid.......
RE: headlight bulbs
man, between you and Chevy Lover, got some crazy diagrams.
