Headlight flashing between being "on" and "off" after a while
I have searched through the forums with no luck. After the headlights have been on for about 5 minutes they will start flashihg between being "on" andthe daytime driving lights. Tail lights never go off or flicker, just the headlights. I would hear a buzz from the relay's in the dash but have rotated them (since they are the same) and no change. I am usually pretty good at diagnosing but this is throwing me for a loop. Could it be the on/off switch?
ORIGINAL: drperry
should be able to just swap it with one of the other relays in there as a test...
And thanks! even though mine was last month
Well a new problem popped up and my rear window won't open , door locks don't work and the power mirrors are dead so I took it in and it is the BCM ( Body Control Module ) that needs to be replaced ...
I was quoted with just a quick price of around $800 to $1000 by GM as I won't get it fixed until after Xmas ..
As soon as it first started acting up that's what I thought it was and my warranty just ran out in September [:@]
Zed
Zed
That bites... It sucks because that's a dealership only fix... The BCM has to be programmed specifically for your truck.
Maybe you should see how much extended warranty is going to cost for like a year, and if it's cheaper, go for that, lol.
ORIGINAL: drperry
I wonder if I could pull that off ??
Thanks !
Zed
