Headlight problems
Hello,
I have a 2000 Chevy Blazer 6 cyl. Every once in a while when I start up the vehicle the headlights will not come on, nor will they come on when I trun on the manual switch.The instrument panel lights up but no headlights. Then after about 5 minutes the headlights come on and I won't have the problem for a few months. Any ideas what causes this?? Dave |
Probaly a short in your wiring, caused by a pinched wire.
Check your fuse. Or maybe its making bad contact were the bulb insert is from dirt and debree?<<<it happened to me a while back on my driver side headlight. |
Or it could be the actual headlight switch. My wires somehow came loose a little bit on the back, so I pushed them back in tight and it works fine now over six months later
| All times are GMT -5. The time now is 07:08 AM. |
