headlights
hey guys im new to the site and im wondering if anyone nows how to get my headlights to stop flickering. i have tried three different relays and it still does it. any help would be great
did you check the actual plug in at the headlights?..possibly loose connection
ive checked that is there a MODULE SOMEWHERE I COULD CHECK ? THEY WILL WORK FINE THEN CLICKING RELAYS START UP THEN THEY GO TO DAYTIME RUNNING LIGHTS THEN BACK ON AND OFF THE WHOLE TIME THERE ON
The daylight sensor may be acting up. I would block the sensor in the dash to see if you then have manual control with the headlight switch.
The only way the low or highs come on is if i push in the switch they dont auto on in my truck its a 97 2dr 4x4 ls
Originally Posted by mr.vls
(Post 247557)
i know that this isn't related to your truck (since you clearly stated that up there). have you checked the actual HL switch for any corrosion on the terminals?:icon_shrug: |
yea the switch looks good should i tryt changing that first , is there a module for the lights i can check
| All times are GMT -5. The time now is 03:56 AM. |
