Heat/AC Issue
By heat and A/C, you are really referring to the fan itself, correct?
If that is the case, then the most probable cause is the blower motor resistor block which is located on top of the HVAC housing under the hood.
I'm having this exact same problem also. The fan does work on level 1 or 2. If I switch it to level 3 or 4 it works. Once I get going, it will then sometimes work on level 1 and 2.
How much is this resistor?
Thanks,
Rick
Thanks,
Rick
ACDELCO Part # 1571991 {replaces 15652873 #15094285, 15652873} Blower Motor Resistor $12.05 - RockAuto.com
That part number is good for both the OPs 2000 and your 1999, C5Longhorn, with manual HVAC controls only.
Thanks Swartlkk,
Is it easy to diagnose whether its the relay or resistor? I've heard that if level 1 and 2 don't work it may be the relay. Either way, I'm happy to see that hopefully it won't be too expensive to repair.
Rick
Rick
