-   -   Heated seats (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/heated-seats-41536/)
pintorio Mar 1, 2010 08:42 AM
Heated seats
Hello everybody. Just recently bought a 02 blazer fully loaded I would asume.
My ? Is i have a driver power seat with no heated seat switch. The passenger seat is not power only lumbar and it has a heated seat. Am I missing something? Thanks for the help.
swartlkk Mar 1, 2010 08:55 AM
Sounds like someone could have swapped either of the seats.
jjnemoiii Mar 1, 2010 07:27 PM
Does the passenger side heated seat work? I believe there is a sensor, so you will need to start the blazer, sit on the seat, and turn on the heat. In mine, switch down was low heat, middle was off, top was high heat. I agree that one seat or the other was probably replaced. Is there an extra connector hooked to nothing under the drivers seat?
pintorio Mar 1, 2010 10:12 PM
The passenger seat works when the seat belt is buckled.
I'm going to have to look under the driver seat to see if there is any loose connectors.
