heater bypass
heater bypass
Until I can fix my blend door I want to bypass the heater. Can I just put a shut-off valve on the heater hose coming off the water pump?
i would think it would be easier to just get a small length of hose and connect the in and out of the normal core line on the engine...loop one right into the other.
or what i did is used a dual ****** fitting thats pvc and some pipe clamps cost 2 bucks
Just fixed my blend door today. Took out the control module, took it apart and the big gear was broken. Glued it back together with 5 min epoxy, put it all back together and was able to see it move when the ac was turned on. Hopefully this repair will last a while.
tilleyvideo
08-05-2009 08:10 PM
krystle
06-28-2009 08:56 AM
