HELP! Battery light on no RPM and oil gauge 0? 99 Blazer
Hollo.
1999 Blazer LT, 4,3L. Looking some help or info. Today while driveing aprox 70 km/h or under My Blazer died on Me. First came on the Battery light, then the RPM`s and oil pressure cauges drop simultaneously to 0 but the engine was running and the motor had very little power. So I desided to pull over and tried to restart the car, but no luck. It wont start now. At first I thought some electrical issue or the generator. But why the loss of power and the gauges needle`s dropped like that? Now My car is on the side of the road and I need it to be towed. Not shure about pulling it with another car because the transmission is automatic. Some help about towing is needed allso. Pulling or trailer?? :icon_cankick: |
Sounds like an electrical issue. I would start by getting the battery and alternator tested. you gauges may have died due to lack of power.
I am inclined to think thats similar To My problem
https://blazerforum.com/forum/2nd-ge...problem-42968/ and yes it could be the generator a.k.a alternator. My Blazer allso hesitates to go gear up at 60-70 km/h. |
anybody knows what kind of alternator do I need for Chevrolet Blazer LT 1999, 4,3L Vortec, 4AWD, 4-door?
I was asked if You want 100 amp or 145 amp (If I was palaying Sherlock on prices)? Did`nt know how to answer that :P |
(Post 666980)
First came on the Battery light, then next the gauges dropped after 2-3 seconds. I taped the gas pedal very lightly and no change on the RPM`s. I turned the car off and could not restart it again. :confused: |
Originally Posted by Bullseye
(Post 666982)
(Post 667015)
I didn't know that 145 amp was an option with the factory style. I upgraded to a DR44G out of a 2005 Silverado.
The standard alternator is 100 - 105 amps. Oddly enough Rockauto lists the DR44G as an option for my 2000. However, they do not mention that a DR44G (145 amps) requires a 1" longer belt.
| All times are GMT -5. The time now is 10:15 PM. |
