Help, I screwed up on a multi switch replacement.
Hey all.
While working on my Daughter's 1997 Chevy Blazer(It needed a new heater core and the Multi switch was flakey.) I lost the connector to one of the plugs on the Multi switch. It has 4 wires and is about 4 inches from the plug that bolts in. Right now the car also has a constant tone. Like the one that is there for when you leave the key in the ignition. If someone could trace their wires and tell me where they go under the dash I would be grateful. I have been working on her Blazer for a week now. While I am glad that the Heater core works I really should have only tackled one issue at a time. Thanks for any help you can give me.
James
James
Actually there are two plugs coming off of the multi switch. One is green and has two wires and the other has 4 wires. The green one is to the little switch that goes to the ignition. It is plugged in. I just need the other one.
So I found out that the plug that was blank went to a plastic ring that is on the bottom of the steering column. It is missing on my car. I am not sure if it got busted off or if it is just not on the 97. I will need to find out. I am also not sure what this ring does.
Joop Gisbers
Dec 28, 2012 10:53 AM
wings4kites
Apr 27, 2011 11:22 AM
illinois99blazer
13
Dec 2, 2008 07:20 AM
