Help - Rough Running P0171/P0300
There is a gear on the distributor drive shaft that meshes with the gear on the camshaft:
If the distributor housing is not aligned correctly in the intake manifold, the gear wears and the shaft will not rotate smoothly and true.
Welcome to the forum! Post #7 above should take you to the problem, If not, it would be best for you to start a new thread describing your symptoms.
RandyRhoadsFan82
Nov 14, 2013 10:52 PM
Klturi421
34
Mar 19, 2012 10:11 PM
ICEMAN616
Aug 24, 2011 11:40 AM
