Heater/AC stuck on hot/cold or intermittent blasts of cool air?
I found this posting extremely helpful to replace the blend door actuator. Apparently "the book" calls for the dash to be removed to replace this $145 part from NAPA. This post shows you how to avoid removing the dash while still completing the repair. It should be noted that I have the Electronic Climate Control (ECC) which controls the blend door actuator. It is a very similar, yet different part if you have the manually controlled heat/AC.
https://blazerforum.com/forum/articl...ferrerid=22431 |
this thread helped me out alot when doing my intake manifold gasket
D-tips |
Originally Posted by scottl1346
(Post 489149)
D-tips |
We need to add to this & keep it front line IMO.
Way too many are asking what are 'generic' questions that answers can easily be found if they searched. Most I just don't want to answer because of that. https://blazerforum.com/forum/articl...-switch-33465/ https://blazerforum.com/forum/tech-a...agnosis-23038/ https://blazerforum.com/forum/tech-a...gnostics-7683/ https://blazerforum.com/forum/tech-a...ill-help-7180/ How do I get the Search link here? Someone please add the Search link in here lol |
Howto fix the buzzing in the window molding B-pillar panel.
https://blazerforum.com/forum/2nd-ge...w-panel-94245/ |
2wd upper control arm replacement with pictures
Plan on all day - and that's just for reading the sticky!
https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/replacing-uca-2002-rwd-pictures-97791/ The frame bolts are the hard part; https://blazerforum.com/forum/attach...lt-diagram.jpg |
| All times are GMT -5. The time now is 07:07 PM. |
