hey guys the whole panel on the left side of my dash wont light up..
Old Oct 8, 2007 | 06:22 PM
muleman's Avatar
muleman is an unknown quantity at this point
Default hey guys the whole panel on the left side of my dash wont light up..
i have a 96 zr2.. the panel where the headlight switch, the rear defog, the dimmer....when you turn on the headlights the you cant see the switches at night are not not lighting up... took the panel off and checked the connections.. nothing... what fuse should control these... or what would cause.. thanks...
Old Oct 8, 2007 | 06:25 PM
coplinb's Avatar
coplinb is an unknown quantity at this point
Default RE: hey guys the whole panel on the left side of my dash wont light up..
have you checked to see if the bulbs are burnt out?
Old Oct 8, 2007 | 10:07 PM
muleman's Avatar
i dont think there is a bulb that lights them up,, because when you push the headlight button on, nothing lights up and i diddnt see a bulb in there........
Old Oct 8, 2007 | 10:34 PM
davtak's Avatar
If it was a fuse, then the other panels wouldn't light up either since they are on the same fuse.
Old Oct 9, 2007 | 07:58 AM
TripleBlackBlazer's Avatar
There is a single bulb that lights up the headlight panel. I took it apart one day to see if I could make my own white face panel. I DO NOT RECOMMEND TAKING IT APART! I had springs and ball bearings and clips flying everywhere and it took me a couple hours to finally find the spring that had gotten away.
I can't remember if the bulb can be accessed without taking the panel apart though. If you do decide to look, just take apart your dash, unscrew the small bolts holding in the panel and unclip the wires connected to it. Look at the back of the panel and if you can do it without getting into the internals, the bulb will be right on the outside. Otherwise-live with it, take it apart and replace the bulb, or take it to a shop. I think in my frenzy I asked swartlkk for a blow-up diagram of where the parts go and he said it was a non-servicable part. You may have to get a new headlight panel from a junkyard...
cahlersmeyer
Nov 8, 2011 04:12 PM
Wexinlo
Apr 6, 2011 11:35 PM
buddanicholson101
Aug 6, 2010 08:49 PM
damageinc98
Jul 12, 2010 10:47 PM
kiwi
Nov 6, 2009 10:45 PM
