hood latch cable
Old 06-25-2013, 10:12 PM
abig84's Avatar
Originally Posted by Toby Hanson
Here's what I did: I clamped a fishing weight between the ferrule at the end of the cable and the latch.
ha, that is a really good idea. i too have had this problem and i usually use a ziptie and just cut off the excess. for as much as i fish i dont know why i never thought of that.
but i think almost every other chevy ive owned ive had to do this
Old 06-26-2013, 01:09 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
I tried the ziptie solution first. They didn't work as well as I would have liked. Maybe later in the year I'll work on a more permanent and successful solution. For now I'm happy with the lead weight solution.
Old 06-30-2013, 11:34 PM
abig84's Avatar
they sell little wire crimping things. no idea what the proper name is but they are pretty much like fishing weights you just smash them onto the wire, that would probably be more of a permanent fix
Old 07-01-2013, 01:23 AM
Ooooh... good idea. I'll have to try that next time.
Old 07-01-2013, 10:45 AM
jim109's Avatar
jim109 is on a distinguished road
have them lowes
Old 11-02-2013, 11:54 PM
CB160's Avatar
CB160 is on a distinguished road
Default HELP!!! Can't get hood OPEN!! :(
Ok, so we all know this is an issue here.... How the hell do you get the hood open if the cable doesn't work?? I'm stuck in my driveway with NO POWER from the battery (probably dirty cables-my fault) and can't get the
dang hood to open....Have tried having someone push down as I pull the cable release to no avail.....
Any tricks to getting this thing open ?
Thanks!
GT
Old 11-03-2013, 03:06 AM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
I've found that after pulling the release hande that if you smack the hood up by the windshield it opens, after spray linelube the latch for the hood
Old 11-03-2013, 08:21 AM
Blazer 98's Avatar
Blazer 98 is on a distinguished road
I pull the release button slowly until I feel it pop, if it is pulled too far then it is hard to open.
Old 11-03-2013, 11:47 AM
383Blazer's Avatar
383Blazer is on a distinguished road
I have more than one GM with a hood release and have found that the latch cam hangs on the release cam tension spring as the hole in the latch cam over time becomes enlarged causing it to bind on the edge of the spring. This is a stamped piece and has a rough edge, take a file and round the edge that strikes the spring and it shouldn't hang up anymore.
Old 11-04-2013, 12:19 AM
CB160's Avatar
thanks for the tips...."if" I ever get it open I'll go over the latch and give it a good tune up.... Dead in the water right now....suspect dirty battery cables....argh!!!
sportf190
15
05-26-2014 04:47 PM
sprbld417
04-25-2011 07:28 PM
7outblazer
08-11-2010 06:59 PM
RevoJer
01-24-2009 10:04 AM
blazer4x4
09-12-2007 11:59 AM
Quick Reply: hood latch cable
