How do I replace this Rag Joint - 95 Blazer
Old Sep 24, 2020 | 07:18 PM
NeoBlazin's Avatar
NeoBlazin is on a distinguished road
Default How do I replace this Rag Joint - 95 Blazer
Just watch and please provide your suggestion of what to do next. Thank You!
Old Sep 25, 2020 | 06:22 AM
LesMyer's Avatar
Take shaft out of vehicle and drill or grind rivets off.
Old Sep 25, 2020 | 05:59 PM
2001ZR2's Avatar
The shaft will side out and you can use your vise to drill out the rivets like Les said there are tons of videos on how to do this.
Old Sep 26, 2020 | 04:33 PM
LannyL81's Avatar
Pull on the shaft with the rag joint; it will pop out, held it with a "spring". Probably will have to lever it out, but it does come out. Then as stated above...grind off the rivets, put the new rag joint on to the shaft, maintain your alignment to the center marks, put some light grease onto the shaft and re-install. Then put the steering box back in, slide the joint onto the steering box, tighten the clamp bolt down (11mm)
DO NOT MOVE THE STEERING WHEEL with the joint off of the steering box.....or you get to learn about a clock spring!!
cleburne red
Dec 30, 2017 12:42 PM
Markolc
Jun 23, 2016 10:29 PM
tashanjustin
Jan 27, 2015 07:44 PM
DKSDAD
Feb 4, 2012 12:08 AM
waldon005
Sep 22, 2011 01:59 AM
