How do I test the fuel injectors for this 4.3L?
In another thread I posted my fuel trims asking questions about them. Long term fuel trims are between -10% and -15%, so someone told me that's likely a fuel injector stuck open.
This is the other thread https://blazerforum.com/forum/engine...m-leak-103649/ My downstream O2 sensor also doesn't look good, so I don't know if the sensor is bad, or if the rich fuel concentration damaged the cat. Can't say how long it's been like this. I'm noticing decreased fuel economy and power/acceleration. So what's the best way to test these injectors to know if they need to be replaced? Or should I just replace the spider-thingy anyway? |
Put a fuel pressure gauge on it. Does it maintain fuel pressure after you shut off the ignition? If it does, your injectors aren't stuck open. Maybe the MAP sensor or coolant temp sensor are not reading accurately and causing it to run rich?
I answered your questions in the original thread.
George |
Originally Posted by Tom A
(Post 735926)
MAP sensor has been replaced recently, but I bought a cheap one. https://www.rockauto.com/en/moreinfo...pt=11207&jsn=8 I hear a small vacuum leak around the manifold that I haven't been able to locate yet. I guess I could take a look at the temp sensor, but I haven't seen the gauge act weird. |
Spray water around the suspected leak area a listen for Rpm change.
George |
Originally Posted by RedValor
(Post 735956)
It does maintain pressure. At least last time I looked at it. I'll have to confirm it again.
@Tom A
I pulled some data and shared it in a different thread. https://blazerforum.com/forum/engine...m-leak-103649/ The challenge for me is understanding what the data means. I know what "correct" should look like. My dumb way of trial and error is to install a new part or swap and look for changes to find improvement. |
One thing to keep in mind , building on Toms point is that swapping out a perfectly good AC Delco part with an inferior after market part can cause even more problems. Swapping with a known good part has its place but not if proper testing is possible. Example: a crappy after market cat can fail in a few months but a proper factory cat is very expensive and then there is the welding and labor. Why would you do that when it can be tested and its function verified?
Cold engine, off: ECT is ambient IAT is ambient MAP is ambient TPS is smooth with proper endpoints through the pedal travel Warm engine: ECT is operating temp O2 sensors are switching correctly and respond properly to forced lean and rich Fuel trims are less than 10 (ST+LT, each bank) MAF is in the ballpark at idle and proper at full load shift using a VE calculator If problems: Check 5v hi & lo ref if used Check wiring and connector Test sensor out of the truck if possible such as an ECT in boiling water George |
| All times are GMT -5. The time now is 02:49 AM. |
