how do i test temp control switch?
i think i might have my problem narrowed down to temp control switch. how to i test to see if its operating properly? The only thing it says in my haynes manual is howto take it out and put it back in
thanks for the help
thanks for the help
Take vac hoses off from temp control and find a hose you can jump it with and watch your actuators that control your vents under the dash and see if they move.I believe it is a black hose comming into the cluster that has the vacum.See if the vents work when you use the jumper hose and if they move then I would say it is the selector switch is bad.Its $100.00 from dealer.
zakm0n
01-09-2011 07:31 PM
cide
11-08-2010 08:17 PM
matclark
06-30-2008 02:24 AM
USMaverick101
10-31-2006 03:10 AM
