how to fix a 4x4 blazer the cheap way
https://youtu.be/NrwxoRYCIvY
Link no worky. What is it?
OK just watched it. That works, at least for awhile. The slide collar won't stand up to continuous use, I don't think, or at least hard wheeling. It's a dumb design from the factory, for sure. Best to just do the bravada shaft mod, and be done lol |
i live in a poore area we cant spend money on things like that so we cum up with fixes on the cheep and ive had this blazer a year an its allwase worked for me
I feel ya, man! If it works for you, go for it! You can get the bravada shaft and tube in a junkyard for around fifty bucks, though. All you really need is the shaft, you can reuse your old tube, just have to make a block off plate for where the cable goes in.
I'm just a little biased against the stock axle disconnect. It's left me stuck without working 4wd in a couple of crappy situations. I had a homemade posi lock setup, and the slide collar wasn't engaging fully. |
Lol I've been running mine like since I bought it 6 or 7 years ago. I only disconnect the front axle on longer road trips.
Originally Posted by Hess13x
(Post 710046)
Originally Posted by cleburne red
(Post 710053)
Man, y'all have better luck than me! I had to replace one of the gears, it was all chewed up from partial engagement, and wouldn't lock in. Then, it came unlocked on me when i actually kinda needed it. It felt engaged by hand, but under load it would slip and leave me in 2wd.
He ended up replacing a bunch of s#it. I do keep a pair of vice grips handy. Used to be for my seat recliner. :icon_dopey: |
(Post 710082)
That's exactly what happened to my co-worker with his 01 Blazer 4 door.
He ended up replacing a bunch of s#it. I do keep a pair of vice grips handy. Used to be for my seat recliner. :icon_dopey: And with the cavalier seat swap, I was finally able to return the vise grip to my tool box! |
(Post 710084)
All you gotta do is swap the bravada shaft in, and never look back lol.
Come on, vice grips cost around the same as the new 4wd actuator. Getting the old one from wreckers should be dust cheap. Besides I wouldn't like a dangling vice grips nearby the battery pegs.
Originally Posted by DonL
(Post 710093)
Did you get pics of those seats in yet?
https://cimg4.ibsrv.net/gimg/blazerf...6f98ee313e.jpg |
I removed my vacuum actuator and have my vice gripped cable tucked under the the battery tray. It works for me. My Jimmy is mostly just an off road toy I do drive it to work but I'm only live a few blocks from work. I need to just swap in the bravada shaft but I'm planning on doing a sas soon.
(Post 710106)
Thought I posted pics in my build thread, maybe not though. Here ya go, either way
(Post 710130)
Ah I remember now, you did post them! My bad lol. Looks good tho. I gotta look into the bravada shaft some more. Would rather have awd then 4x4.
It'll still be 4wd, unless you swap in the Np236 tcase. The bravada shaft just makes it like you've always got your hubs locked in. |
Gotcha
