-   -   How to flush the brake system? (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/how-flush-brake-system-22097/)
KA3AX Jul 24, 2008 09:56 AM
Hello to all again!
I did a search and saw some people talking about flushing/bleeding the brake system, but nobody actually said how to do it. So how do I do it?
Thanks in advance for any helpl:)
WolfPack Jul 24, 2008 10:11 AM
RE: How to flush the brake system?
I've actually been looking for the same info..I wanna get some new brake fluid in..mines got 100k on[:'(]
packofqtips Jul 24, 2008 11:17 AM
open all the bleeders and then keep pouring new fluid in until you think you replaced it all dont let the master go dry or you will have to bleed the brakes
KA3AX Jul 24, 2008 12:56 PM
ORIGINAL: packofqtips
So do I just open all the bleeders and pump the brakes or not do anything and let it flow out? Also should I let the fluid go down almost to the bottom in the reservoir and THEN add new fluid?
Thanks.
WolfPack Jul 24, 2008 03:47 PM
Is brake fluid safe to just drain out and let it run down the driveway? Or is there a better way to catch the old fluid?
packofqtips Jul 24, 2008 03:49 PM
i'd catch it in a drain bucket
