How to pull ABS codes?
My ABS was kicking on a low speeds so I took out the sensors so I could remove corrosion build up under the sensor. One of them broke during removal so I drove around for a week with the ABS light on. I just replaced the broken sensor and the ABS light is still on. I checked the ABS fuse under the hood and it's fine.
Is there some way I can pull the ABS fault code so I at least know which wheel to look at?
