I need a radiator, '01 Blazer. Advice?
I haven't had to buy a new radiator in YEARS, and so I have some questions about the Blazer's radiator and my options for a new one. This is for a bone-stock '01 4.3L. The top/side is cracked on it, time for a new one evidently. Just over 100k on the truck.
1.) Is the stock radiator a single row? 2.) Is there an 'upgrade' I should consider? (didn't really have cooling issues that I know of w/the stock one I guess) 3.) Should I buy locally or online? 4.) Is there any brand I should stay away from? The last time I bought a new rad it was from a local specialty shop that sold cooling parts, but don't even remember the name of that place anymore or know if they're still around. So I called around to the normal chain parts stores to see what brand/warranty/pricing is. They're all pretty close in price, sans Napa & Car Quest being $20 higher on theirs. All seem to carry a limited-lifetime warranty though. Brands were Spectra, TuffOne/Ready Rad, and Murray. Looking online at RockAuto, they offer a "Spectra premium" for just under $100, a "Vista-Pro" $126.79, A "Nissens" $168.79, and an ACDelco.. for $224.79. Is the ACDelco really that much better than any of the others? Taking the listed PN of 20837 and looking on Amazon, I start to get confused because Amazon says the 20837 will NOT fit when I plug in the info :icon_really:.. Huh? Am I okay with any of the other brands off R/A or locally? Or should I spring for the spendy ACDelco... which has conflicting fitment depending on where I look :icon_denk:. While I'm at it.. may as well get a new water pump too. So do I want an ACDelco replacement (which by now I imagine is a China part) or am I okay with whatever any of the local parts stores offer there? Thanks for any experience/advice! |
The radiator is single core it usualy provides siffucient cooling.Maybe you could add an electric fan for better cooling.As for which brand is better I don't know if napa is a better one but it will cost you more this I know.You can buy localy and or online.Its probably going to set you back estimated $150
Like you, I have a bone stock '01 4.3L, mine is 2WD.
Last September, the Blazer had around 195K and I had a leak on the top driver's side and replaced mine with a "ToughOne" from Advance Auto. One reason I went with Advance is because I had a pending $25 coupon from a previous order that was about to expire. The Radiator was (and still is ) $130 before the discount. I've put nearly 15 K on it and have not had any problems with it at all (leaking or overheating). I recommend it. While you're at it, I'd flush everything real good including the heater core, mine was clogged and this was discovered when we had single digit temps one morning! |
I doubt there is much difference in brands of radiators, but one piece of advice for when you get it; before installing it, make sure the fittings that screw into the plastic tanks for the oil or trans fluid coolers are nice and tight.
I replaced the radiator a couple of years ago and thought I had blown the plastic tank seal and was in the process of taking the radiator out only to find that one of the fittings had come loose. A few taps with a screwdriver and a hammer and all was good. |
Thanks for the replies so far!
Originally Posted by 1sttimejimmyowner
(Post 628830)
Originally Posted by Joey1986Z
(Post 628837)
Originally Posted by LannyL81
(Post 628848)
| All times are GMT -5. The time now is 10:28 PM. |
