I removed my throttle position sensor ...
Old Feb 10, 2008 | 01:59 PM
zombiewoof's Avatar
zombiewoof is an unknown quantity at this point
Default I removed my throttle position sensor ...
And now it idles around 2500 rpm...how can I make the idle go back to normal? I removed the negitive battery wire hoping this would reset it...didnt work. I cant beleive i just screwed this up...I let it run for a few minits hoping it would clam down...didnt work...
I was also messing with the idle air control...I cleaned it....I may have pushed the pintle in a bit...how can I correct this?
EDIT....It was the idle air control pintle pushed in...I took it off and pulled it out ...It hardly idled...so I pulled it out a bit more and now its idling at 1500....is this something that takes a while of running to adjust itself?
Old Feb 10, 2008 | 02:29 PM
Chevy Lover's Avatar
Default RE: I removed my throttle position sensor ...
Do you have a multi meter to read the TPS voltage? It should be approx .64v to .67v @ idle or with key on engine off.
If the TPS is correct cycle the ignition a few times. Don't start it, just cycle it. Then you can start the engine with the park brake on and put it in gear (while holding your foot on the brake) and within a minute the IAC should re-set.
Old Feb 10, 2008 | 03:16 PM
zombiewoof's Avatar
Thanks....as long as I know it will reset itself I should be ok....I have the truck on blocks waiting for my muffler to get here tomorrow..I guess I shouldnt be messing with things if I dont know what they do...but then again ..I just learned something
I read in my manual to adjust the plunger to 28mm with the neg bat cable off and thats how to install a new one...so thats what I did...Ill have to wait until I can get it out of the garage to run it under load and reset it, I cycled the ignition a few times and started it (but not for long) and it seemed like the idle was changing from high to low and such...
Old Feb 10, 2008 | 03:22 PM
Let us know how it works out after your muffler is on.
Old Feb 12, 2008 | 11:58 AM
zombiewoof's Avatar
I damaged my throttle position sensor...got a new one and it idles ok now...Thanks
Old Feb 12, 2008 | 12:46 PM
Very good! Thanks for the update!!
Old Feb 12, 2008 | 09:13 PM
Sorry to hear that you damaged the TPS but glad you got it fixed.
importsky22
Aug 27, 2012 07:14 AM
russ1609
Jan 30, 2012 07:08 PM
86Blazer4x4
Jun 14, 2009 11:52 PM
muszyngr
May 28, 2009 02:02 PM
disturbedgame
Feb 12, 2008 05:32 PM
