IAC valve cleaning how-to
Hello,
I have a 98, and would like to clean the IAC. I found the EGR cleanup how-to, but nothing on the IAC. Where do I find this item? Ive seached enough to see how to do it for the most part, my key is knowing where it is. Thanks! |
Idle Air Control Valve.... hmm... check on the side of your throttle body. From a quick google image search most are in generally the same spot. Couldn't find one on a Blazer, but heres a Camaro, so same car company... :p
Click Me |
Oh, OK. Thanks. It seemed that they were all more or less the same,but it was tough to tell. Ill do some digging this weekend - I know Ive never cleaned it before!
Thanks, JMH |
The image posted above shows an almost (if not) identical IAC valve. It is located on the driver side, rear of the throttle body pointing towards the passenger side.
*flex* What can I say... I'm just that good.;)
What type of cleaning solvent are you guys using?
I use CRC sensor safe throttle body cleaner.
Awesome post, I had the exact same questions! Thanks jhzr2 and you 2 guys that answered!!!
just get a can of brake cleaner and your wifes toothbrush. remove iac,scrub and clean it with cleaner,reinstall and smile.
Would the spray type seafoam work? or is that not sensor safe? i just threw my bottle away so i cant check.
And that spray seafoam is amazing. i used it to clean the TB and it turned the heavy carbon into soup. |
| All times are GMT -5. The time now is 05:04 AM. |
