idk what it is but i need help fast......!!
i have a grinding sound coing from the driver side front tire. idk what it is i thought it was my breakes but i changed them and the grinding was still there. someone told me it was my ball bearings going out but im not sure... will some one help me fast i need to fix it so i can start lifting it and putting tiers and wheels on.:icon_hyper:
Help us to help you...year, 2wd, 4wd etc etc the more info you give the easier it is to help
its a 1997 s10 blazer 4x4.
I'd start with checking out the hub assembly search for it there are tons of threads on diagnosing this to be certain before spending the money (they aren't cheap) HERE is one to get you started, let us know what you find and we will do our best to assist further.
okay thanks man. i'll let you know when i start to fix it.
Sounds like wheel hub bearing to me.
are they hard to replace or would it be better to have a garage do it?
You can do it at home, use good parts or you will do it more than one time. Do both sides while you have the tools out.
Justin |
Yupp just do it at home, I (because I'm broke) just did one side and used the hub they sell at autozone and it worked out fine for me. I ended up doing the other side like 6 months later though lol. If you can afford it do both.
Drive at highway speed for 20 mins or so then pull over & feel the front rims near the center. If 1 side is warmer/hotter than the other then there's a good chance it is the hub bearing assy. that needs replacement.
| All times are GMT -5. The time now is 04:20 PM. |
