idling problem and random shut off
Old Oct 22, 2010 | 05:41 PM
spear11's Avatar
spear11 is on a distinguished road
Default idling problem and random shut off
This thing has thrown me for a loop I'm a certified mechanic and I am gettin a headache from this thing it runs great going down the road but once in a while the brake lights come on and it will die if I don't put it to the floor as soon as it comes on, and it will idle real rough and in gear it dies it has every new sensor possible new fpr, intake gasket, plugs wires can someone that has had this problem help me out
Old Jun 22, 2013 | 01:43 PM
figured_it-Out's Avatar
figured_it-Out is on a distinguished road
****Its the CM that is mounted on the heat sink right at the top passenger side of the engine.( Aluminum heat sink...cant miss it..right at the top. the icm is attached to it)
Buy a new one($74), and buy the silver heat paste at radio shack ($14).
take the whole assamble ( heat sink and CM mod) off the braket its mounted to because this is the cause of the problem. The bracket is mount to the engin and IT conducting heat back up from the engine causes all the problems.
After replacing the CM and applying the new heat paste, tye wrap the entire thing on the cables coming from the gas peddle to the top of the engine that are right in front of it , in such a manner that the air flow from the radiator will run down the length of the heat sink fins.
Simply tye wrapping will work fine and there is just enough length on the wires to the CM to allow it to reach.
This WILL finally solve this vexing problem. Simply put it is a design fault.
The CM is heat sensitive and is mounted to a heat sink. the problem is the bracket that ITS mounted to is hotter than hades and conducts the heat back into the CM via the heat sink.....crazy but do what I suggest and THAT problem is fixed...
Old Jun 23, 2013 | 07:32 AM
spittybays
Guest
Posts: n/a
figureditout, you need to take a look at the dates on the top of the posts, lft hand corner, 10-22-2010 with only one post, the guy dropped it and never came back. Don't want get carpel tunnel for no reason.
chester92
Nov 14, 2011 02:50 AM
chaoticdopey
Jun 24, 2011 05:18 PM
yarinzim
Apr 29, 2011 09:23 PM
musclecar70sfan
Mar 23, 2010 03:00 PM
sword2269
Nov 27, 2009 11:23 PM
