-   -   Ignition Switch Replaced - Same Problem... (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/ignition-switch-replaced-same-problem-41011/)
Vandal6947 Feb 18, 2010 12:56 PM
i did exactly what you told me to do and my truck still doesnt run!!!!!!!!!!!!!!! what do i do it has the same exact problem with the new ignition starter switch. security light blinking and no start. what do i do now?????????
swartlkk Feb 18, 2010 01:11 PM
*Moved from the How To: Ignition Switch Replacement DISCUSSION thread into a new thread in the 2nd Gen Tech section* - The Article Submission/Discussion forum is only for submission of articles and discussion of said articles and is not meant for tech support.
Did you do the security relearn which is required after replacing the ignition switch?
*EDIT* - I see that there was a problem with the link to the passlock relearn in the tech section. I have fixed this issue. Give that a try.
