I'm either lucky or getting really good with a dist
So, I was on the way to work the other day and just as I was getting on the interstate, the RPM drop to zero. Tried to crank it, nothing. Used my scanner, came up with P0340 (can sensor circuit malfunction). Popped the hood and checked the dist, and it wobbled pretty easily.
Had it towed home, went and got a brand new dist from Autozone and put it in the same way I did with the old one. Set it in, button it up, try to start. If no start, turn the rotor 180°. Still no start, pull the dist and tap the key to spin the cam without spinning the oil pump. Install dist, try again.
I did this with my new dist, and hit it solid. Starts right away with a touch of the key. No miss, no hesitation, idles smooth and quiet. Cleared the codes and checked it a couple of times, no P0340 or P1345.
Am I really that lucky?
As for the old dist, i got that one from a junkyard, I think the ticket said it came from a 2001 Blazer. Same model, I know, but I guess it had a bit of wear already. The new one should be okay for awhile at least, since it's new. This weekend, I'll be ordering a Delco cap and rotor just to be sure.
daddyx2
07-02-2012 09:50 PM
