Injector compatibility question.
Old Oct 8, 2012 | 01:55 PM
nalgman's Avatar
nalgman is on a distinguished road
Default Injector compatibility question.
hello..
im having trouble with my blazer. (there's another post for that)
i have a general question..
what years the Injectors Fit to a 2001 Blazer?
i have seen that all the injectors are pretty the same thru the 2011. for the 4.3 engine.
thank you for you time!
Old Oct 8, 2012 | 02:21 PM
50lb_cat's Avatar
In 95 they went to CSFI fuel system ( they also had CPI) so 95 is a mix. From 96 to 02 they only had CSFI system. As of 02, they went with MFI, and that is a superior design than the old poppet style of the CSFI. So, if you are replacing injectors, I would just get the conversion kit and install the MFI system.
Old Oct 8, 2012 | 02:36 PM
nalgman's Avatar
oh i get it...
the tip of the injector it's what's change...
i dont know yet if my fuel injection system has a leaking or something.. but if i have to replace this.. i would looking for this part at amazon.. FJ503
thanks man..
im learning so much !!
Old Oct 8, 2012 | 03:00 PM
50lb_cat's Avatar
For that price, you are better off going to rockauto.com ad getting a delphi MFI conversion. You will need a new bracket, or you can modify the old one. There is also a 5% discount floating around somewhere lol. With these trucks you always want to stick with delphi or delco.
Old Oct 13, 2012 | 02:38 AM
nalgman's Avatar
Default injector
near to my home. there's a lot of junk yards.
i wonder if a silverado 2010 fit to the 2001 blazer?
thanks
Old Oct 13, 2012 | 12:12 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question
My question would be how are they superior over the cpi?Both use a spider injector inside of the planem and have popet style injectors.When the spider goes bad they both cost $300-$500 brand new.
Old Oct 13, 2012 | 12:14 PM
thanks
I highly doubt 2010 set up will work on the 01,If I remember corectly they made changes after 02.
EDit I looked it up says up to 2007
Old Oct 13, 2012 | 12:49 PM
nalgman's Avatar
Default Jets
Well this becauuse the part mumber Fj10565 its a delphi spider with a regulator and it say that would fit to 2002 and up. Because its a new design and other stuff.
My other question ie.if i purchase this part number,it would fit to my 2001? Some people say that its a direct replacement with no modiffication.
Thanks
Old Dec 4, 2012 | 10:36 PM
rockp2's Avatar
Default 1998 with CPI?
Guys I'm kind of confused here. My vehicle is '98 Blazer ZR2, 4.3L, Vin "W", 5-speed manual. I have been going thru all my RPOs on the firewall and in the glove box. As far as my engine goes the RPO is "L35" which checks out to be "Engine: 4.3L V6, CPI".
Is there any physical difference in the Vortec 4.3L engine itself (less intakes, top end, exhaust, etc), or the PCM that would have to be considered, regardless if you have a CPI, SCPI, MFI, etc? Re-flashing or anything required? Thanks.
Old Dec 5, 2012 | 10:23 PM
1995 and older "W" engines are CMFI, (Central Multiport Fuel Injection) one batch fired injector, 6 "spider lines", with poppet valves in the ends.
1996 and newer "W" engines are CSFI, (Central Sequential Fuel Injection), 6 sequentially fired injectors in one housing, 6 "spider lines", with poppet valves in the ends.
2001 and newer "X" engines are SMFI, (Sequential Multiport Fuel Injection) Also known by several other names. 6 sequentially fired injectors located at the intake ports with no poppet valves.
All 1996 and newer "W" engines can be upgraded to the SMFI system. Plug & play, no PCM flashing necessary.
Delphi FJ10565 kit, (~$230) comes with the new bracket but you need to purchase the gasket set. Noticeably better performance than CSFI.
ScarletIce
Jul 10, 2014 07:08 PM
dj00740
Jan 17, 2014 09:10 AM
Cerpindicular
Apr 23, 2011 11:33 AM
ShaitanWampyr
Oct 10, 2010 10:05 PM
tkf5651
May 29, 2008 09:13 PM
