-   -   Installing factory fog lights (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/installing-factory-fog-lights-36976/)
Dogger 11-14-2009 08:19 PM
Has anyone added factory fog lights using the OEM switch?
Monkeyman 11-15-2009 04:08 AM
Depending on the year, it has to go through the BCM. Dealership told me it would cost close to $100 for them to reprogram it so I told 'em to fook off.
cc4usa 11-15-2009 01:02 PM
why couldnt you just put in the factory fog lights and run your own switch
its not rocket science
Monkeyman 11-15-2009 01:33 PM
Nope, not rocket science but if you want to use the stock wiring it more involved than just adding a switch. Besides, the factory switch is there, it looks stock and it's out of the way. Someone once mentioned some sort of relay you can buy that will allow use of the stock momentary switch but I don't know what kind it is. If I knew, I'd use it with the stock switch.
RonJon 11-15-2009 08:13 PM
Here's a link on how to wire up 2 relays to achieve a momentary switch to constant relay output connection. http://www.the12volt.com/relays/page5.asp#mtc The Orange wire coming from your fog lamp switch connector will be the (-) pulse. Also if you connect a wire from the constant 12v+ output (fog lamps) to the purple wire in the fog lamp switch connector, it'll light the indicator lamp when they're on.
