Intake manifold gasket
I have a 95 Blazer and the lower intake manifold is leaking antifreeze. Can anyone recommend what brand gasket kit set I should purchase, including valve cover gaskets?
Thanks bizzs |
Felpro is the gasket of choice around here.
Thank you, I read that.. I could not find the entire gasket kit for a 95 blazer. Would you happened to know what the part number would be?
Thanks |
I used Felpro MS 95817 a few years back on a 96 4.3-Any quality jobber will be able to provide this...
I was looking at that, but rockauto said that it does not fit a 95. It is difficult to find the entire gasket kit including intake, valve cover, plenium,and rotor gasket etc. Can anyone else recommend the part number including all the above in a kit?
thanks, bizzs |
definitely fel pro without question
You stated 95 in your original post,then said 96 in a later post. Yes the 95 is different,but only in the ancillary gaskets(plenum) but you do not have to break apart the upper intake to do this job.I believe the actual intake to head gaskets are the same as are the Valve cover gaskets.The distributor gasket is the same as every small block from 1955-2005.All these gaskets are available in a set or separately:Fel-pro,Victor,Mr.Gasket etc. Buy your gasket set locally to avoid any headaches in the event of error!
I used FEL-PRO Part # HS9354PT4 for my 95.
Right,but that is a complete head set, that is not required for the LIM gasket job.
Lower intake manifold gaskets are different 92-95 from 96+. Different number and position of intake to head bolts
| All times are GMT -5. The time now is 06:11 AM. |
