-   -   Intermittent AC (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/intermittent-ac-105702/)
jk69jarvis69 May 31, 2023 03:22 PM
Intermittent AC
05 blazer, when i turn on my ac it usually works and blows cold for a few moments and then a ‘cheep’ like sound comes out of the compressor area and the cold air stops and it blows warm, if i rev to about 3k rpm’s the cheep happens again and the ac starts blowing cold for a few more minutes. i’ve read a few threads but can’t seem to find anything like this happening. any advice is appreciated
Walleye Hunter May 31, 2023 04:04 PM
Probably low on refrigerant. Best way is to connect gauges to it and see what your numbers are. You can get loaner gauges from AutoZoo. Search the interwebs for information.
puttster Jun 1, 2023 09:33 PM
I didn't know that, good info! Usuallu I just add a can, I might try the AZ gauges next time.
arstinince Sep 12, 2023 04:03 PM
​​​​Yep, sounds like low refrigerant. After it drops below a certain psi, it'll start working intermittently, until it loses a bit more and stop altogether.
Common leak points for these are the shrader valves on the low side, high side, and behind the cycling switch on the dryer. The o-rings flatten over time and fail.
Good luck!
puttster Sep 20, 2023 05:21 PM
Best add a can while you can. If you wait till there's no coolant left, the compressor won't kick in and it's a lot more trouble.
