-   -   Issue closing Sunroof properly (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/issue-closing-sunroof-properly-41557/)
jjnemoiii 03-01-2010 07:50 PM
Am I missing something? Am I not all there? (never mind, everyone knows I'm not). I love to open the sunroof, but can't seem to close it correctly. If you push "close" too long, it pops up the back side an inch or two. I have troubles finding that sweet spot, where its completely closed. I usually get out and look from the outside while I push the button back and forth until it's closed correctly. Is there an easier way to close it, maybe even from inside?
Sisk 03-01-2010 07:56 PM
It shouldn't tilt up unless you release it and press it again. They close should close flush as long as you hold it. Once you release and press close again is when it tilts. I've never had that issue with mine...
Also, when it's tilted it's the same thing. You can hold it until closed, and it shouldn't auto-open until you release and press again.
And a tip...please post your vehicle info in your sig or your post when you're posing a tech related question. I'm assuming you have a 2nd gen since you posted it in the 2nd gen board, but it makes troubleshooting hard when we don't know what you have for a vehicle.
jjnemoiii 03-01-2010 08:05 PM
Sorry, I'll add that asap. 2001 Blazer 4x4 94,000 miles
Sisk 03-01-2010 08:06 PM
No worries..same as mine. Give my suggestion a try. It should work for you. If not, you may have an issue with your switch or motor.
jjnemoiii 03-01-2010 08:18 PM
Thats how I thought it should work, but many times it seemed to keep going. just tried it several times, worked just like you said. Thank You for the help.
Sisk 03-01-2010 08:44 PM
No problem. Glad to help.
pmanwarren2015 04-13-2016 08:07 PM
i just put a kit in mine and now my moon roof only goes half way any help would be great
