Issue i been haveing
Old Sep 9, 2012 | 12:08 PM
superdragon's Avatar
superdragon is on a distinguished road
Default Issue i been haveing
hi my name is rob,
about 3 weeks ago i started a new job, after work that day my 2000 blazer spit sputterd and stalled. after i got it jumped it drove fine all the way home, about 4-6 miles. 2 blocks from the house it did the same thing(pushed it the rest of the way it wouldnt start) i think it was the gas. well put some fuel in it and some dry gas and it started and drove to the same spot about 2 blocks from the house and spit sputterd and stalled again but this time i got a puff of smoke outa it not sure where it came from. and well after that i get it home and now im not geting any spark.
i have checked the cam sensor, the coil, and the ignition module. any ideas on what else would make it not spark?
anything will help i havnt put much money into it and am curiuos what it could be. i did just replace the battery and the alternator.
Old Sep 9, 2012 | 03:18 PM
warthogdriver's Avatar
did you check the dist cap and rotor?
Old Sep 10, 2012 | 05:33 AM
Yes I have. Sorry thought I put it up there with the rest
Old Sep 10, 2012 | 03:31 PM
Pull the coil wire out of the distributor cap, slide the boot back to expose the terminal, rest the terminal within a half inch of ground, attempt to start the engine while watching for spark. Should be a blue, not orange, spark. Post your results.
Old Sep 10, 2012 | 03:42 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
If it works then all of a sudden doesnt then i want to say its the ignition switch, but it could also be the coil. So i would do what the captain said and if you have no spark first thing to do would be get a new coil and if still no spark then i would lean towards ignition switch. Captain will probably have better thoughts on that tho lol
Old Sep 10, 2012 | 04:44 PM
The ignition switch is a definite possibility, although it's not very common on 2000. 1997 had an extremely high failure rate, and it's the only year that part number was used. If there is no spark from the coil while cranking, the next step is to make sure there is battery voltage on the pink wire when the ignition is on. Then disconnect the electrical connector from the ignition coil and see if the white with black stripe wire has a pulsed ground signal while cranking. Just a matter of checking for voltage on the wires until you find the problem. You can start at the PCM, which tells the module when to fire the coil, or at the coil and work your way back to the PCM, doesn't matter.
Old Sep 12, 2012 | 11:49 AM
well i tried your lil test on the wire from the coil to the dist and got nothing. i started to follow the other wire into the coil and was going through it see if anything was amiss and well i was pulling electrical tape off to get a good look at the wires and the wires and the plug into the the coil snapped off in my hand with the slightest pressure on it so i got to look at the wire and its burnt and rotted i guess u could say. now i got to replace that. i think thats where my problem was.
Old Sep 12, 2012 | 11:50 AM
thanks for the help anyway guys. i will probably be posting here in the future on other things.
Old Sep 12, 2012 | 11:52 AM
Sounds like you found it. Let us know what happens.
oh and capt where is bellville in relation to lansing?
