Jam on Brakes from idle speed then engine dies and won't start.
Alright so I went to cross a busy 2lane highway and when I went to go a guy came over the hill real quick on the highway so I jammed on my brakes (idle speed) and the engine dies, and cranked like 5 times before it would start. What may cause this? It happened a long time ago too but I thought it was just a fluke thing
500 in gear, fully warmed up? That doesn't sound too bad. Could be higher.
When you press on the brakes, can you hear air rushing in around the brake booster that would indicate that there is a vacuum leak when active. Shortly after shutting down the engine, pull the check valve out of the front of the brake booster, is there a rush of air into the booster?
*Update,
No air sound to the brake booster pressing on the brakes, and when I shut off the engine and pull off the vacuum hose off the booster air rushes in, so that would indicate there is no vacuum leaks correct?
goslats
15
Jul 31, 2015 09:19 AM
ernestiv
Apr 18, 2015 03:02 PM
barnesto
31
Jun 11, 2014 07:12 PM
TTATE
Aug 11, 2009 07:43 PM
