Key fob trunk release
Hey y’all
I was wondering should I get a key fob with or without a trunk release button? i found out that My 99 blazer has AU0 that means i have the RKE system right? |
I found that if you have the button on the back hatch, you only need three button as it unlocks as a door.
not sure if that helps... |
Originally Posted by DonL
(Post 722197)
not sure if that helps... my truck does have the hatch button |
You can get and should use a 4 button FOB, Its extremely useful because the rear glass opener button fails pretty often due to the contacts getting jammed with carbon. and its a right bitch to fix
| All times are GMT -5. The time now is 07:07 PM. |
