Key wont go to accessories position.
Old Feb 7, 2021 | 04:47 PM
Revjack's Avatar
Revjack is on a distinguished road
Default Key wont go to accessories position.
97 blazer lt 4c4
Bought a used blazer resently and the previous owner said he thought his son might have broken yhe key in the ignition switch. It would start without a key. The buzzer was always on. And it wouldn't go into the accessories position. I bought a new cylinder but it still wont go to accessories, and if i install it with the key in the cylinder. It wont come out. If i install it without. The key. It is ecactly like when i bought it.
. Im wondering if there is something in the columb i can check.
Old Feb 7, 2021 | 04:49 PM
Revjack's Avatar
I really hate typing on a cellphone.
Old Feb 7, 2021 | 10:51 PM
chevyriders's Avatar
moved to 2nd gen tech section, new member area is just for introductions.
i would double check and make sure the new one is installed properly and seated all the way. maybe remove the new one and test it while its uninstalled. this should tell you if the switch is the problem, or if you have to look deeper
Old Feb 8, 2021 | 01:51 PM
Revjack's Avatar
I have replaced the lock cylinder including the key.
i have removed. The swith and checked that it will go into acc position. I have jiggled the steering wheel. I have tried mpving the floor shifter back and forth. Some cars have amanual telease, but not this one.
any other suggestions?
MetalMan390
Jan 21, 2011 10:27 PM
97Bravada
Jun 22, 2010 09:48 AM
a68cudas
Feb 9, 2010 10:42 AM
bjsx8f
Aug 22, 2008 03:55 PM
Booztd
Jun 1, 2007 09:47 PM
