keyless entry mod?
i have a 98 4D blazer, and it doesn't have key less entry, it would be nice if it did, and i was wondering if i could get one out of a junk bravada jimmy or blazer, what parts will i need, im thinking it would be the wiring for the doors, and some receiving unit, but idk were thats located at
if it's like everything else, it should already be wired in (power seats style)...
I dunno on this one though... when you go looking for it, you will need a brain (behind the d side hush panel: http://s-series.org/albums/album44/hush_panel.sized.jpg and check the FCCID to make sure you get the right key fob to program to it. i did a search for RKE and came across some gems like Adding RKE and Keyless Entry there is a bunch of info in here :icon_teeth: |
thats it right there? well its easy then right?
so long as you have the wire harness it SHOULD be plug and play with a programed matching remote :icon_shrug:
search it up though... it's uncommon for this to come up :icon_teeth: |
ok, so its under my dash? i read somewhere just now its inside my drivers door... ima go look right now for wired, and i wanna know exactly were to look... and what the wired look like
use the pic above... if there is no box, but the harness is tucked up inside... then WIN!
in older vehicles... like say a 93 bravada, it would be under the cup holder 9from what i read looking for this for you)... never saw it being in the door... maybe they were talking about the accuators that run the locks :icon_shrug: |
ok, i looked were ur picture showed, i found a small connector with 2 orange wires and i thing a black wire with a white strip, is this it?
dunno...
https://i306.photobucket.com/albums/...90/RKE_DLC.gif LOOKY HERE super useful thread from search |
i swung my by local dealer Monday and asked them about this mod, he thought i was an idiot, and told me that if it didn't already have key less entry, there wouldn't be the wiring there for it, now i found something under there, and i think that what it is, so this will for sure work if what ur saying, im getting a receiver out of a 2001 jimmy, and i have a 1998 blazer... id like to do this, and if i can, i guess id have to find a different dealer to program it for me, cuz my local one, has no clue apparently...
Check your RPO code's in he glove box
the GM parts can run the VIN and print out all options or use http://www.compnine.com/vid.phpr if you have the option all you will need is the key fob http://www.yourkeylessremote.com/(S(...)/default.aspx |
| All times are GMT -5. The time now is 07:10 AM. |
